LabWindows/CVI
Read a specific sheet in a excel document...Please help!
First I start Excel then I read a specific excel document which has 5 sheet`s and the 1 sheet is active:
GetProjectDir (fileName);
strcat(fileName, "\\Logiciel_FH.xls");
error = Excel_WorkbooksOpen (ExcelWorkbooksHandle, NULL, fileName, CA_DEFAULT_VAL,
CA_DEFAULT_VAL, CA_DEFAULT_VAL,
CA_DEFAULT_VAL, &ExcelWorkbookHandle);
// Get Active Workbook Sheets
error = Excel_GetProperty (ExcelAppHandle, NULL, Excel_AppSheets,
CAVT_OBJHANDLE, &ExcelSheetsHandle);
error = Excel_SheetsItem (ExcelSheetsHandle, NULL, CA_VariantInt(1), &ExcelWorksheetHandle);
// Make First Sheet Active - should already be active
error = Excel_WorksheetActivate (ExcelWorksheetHandle, NULL);
After I write some data in this sheet and start a macro function I want to read the sheet number 4....so I tried to do this:(but still it reads from the 1 sheet.)
error = CA_VariantSetCString (&MyCellRangeV, EXCEL_ARRAY_OF_CELLS);
error = Excel_WorksheetRange (ExcelWorksheetHandle, NULL, MyCellRangeV, CA_DEFAULT_VAL, &ExcelRangeHandle);
CA_VariantClear(&MyCellRangeV);
error = Excel_SheetsItem (ExcelSheetsHandle, NULL, CA_VariantInt(4), &ExcelWorksheetHandle);
// Make range Active
error = Excel_RangeActivate (ExcelRangeHandle, &ErrorInfo, NULL);
// Ask for the ith by jth value of the range which returns a dispatch to a new single cell range
error = Excel_RangeGetItem (ExcelRangeHandle, &ErrorInfo, CA_VariantInt (12), CA_VariantInt (2), &MyVariant);
// Get the DISPATCH pointer
error = CA_VariantGetDispatch (&MyVariant, &MyDispatch);
// Create a new Range Object from DISPATCH pointer
error = CA_CreateObjHandleFromIDispatch (MyDispatch, 0, &ExcelSingleCellRangeHandle);
// Get the value of the Single Cell Range
error = Excel_GetProperty (ExcelSingleCellRangeHandle, &ErrorInfo, Excel_RangeValue2, CAVT_VARIANT, &MyVariant);
error = CA_VariantGetCString (&MyVariant, &d);
printf("%s\n ", d);
CA_VariantClear(&MyVariant);
ClearObjHandle (&ExcelSingleCellRangeHandle);
Can you tell me where I`m doing wrong...?? What should I do to make the program read from the sheet number 4??
Message Edited by Annees on 06-10-2010 03:40 PM
(4,704 Views)
Accepted by topic author Annees
I have used in the past some code very similar to yours, with one exception which is to close the handle to the active worksheet before acivating a new one. In this case the code should look like the following (note the lines in red):
error = Excel_GetProperty (ExcelAppHandle, NULL, Excel_AppSheets, CAVT_OBJHANDLE, &ExcelSheetsHandle);
// Handle to the first sheet
// Clear the handle to the active worksheet
error = ClearObjHandle (&ExcelWorksheetHandle);
//error = Excel_GetProperty (ExcelAppHandle, NULL, Excel_AppSheets, CAVT_OBJHANDLE, &ExcelSheetsHandle);
// Not needed: you have not overwritten ExcelSheetsHandle variable which is still valid
// Handle to the fourth sheet
// Make Sheet Active
printf("%s\n ", d);
As a side note, you are not using error checking and probably have disabled the break on library errors: you should have recevied some error when trying to access the new sheet: consider adding a proper error handling and be sure in this case to clear all active objects before leaving the function.
(4,688 Views)
Can you give me the project ,it's urgent
I need this method because I added this code in my project  to display in table under cvi
(3,551 Views)
JJHGH,
stop hijacking old threads and read the documentation and examples I link here!
(3,548 Views)
