LabWindows/CVI
Read one line from File
Hello.
i will read alwas one line from the file.
Can you give me a comando?
(3,783 Views)
Just use the ReadLine function. Check the returned value to see the number of bytes that were read from the file.
(3,780 Views)
thanks for your answer.
Can you send me the metode how i can detect the end of the file.
In the Errorhandle isn't a message.
wolf4124
(3,775 Views)
the function ReadLine returns -2 if the end of the file is reached, and -1 if an error occurred. Here is some piece of code to show you an example:
 filehandle = OpenFile (pathname, VAL_READ_ONLY, VAL_OPEN_AS_IS, VAL_ASCII);
 // Check if the file could be opened.
 if (filehandle == -1 && (error = GetFmtIOError())){
  MessagePopup ("Unable to open the file", GetFmtIOErrorString (error));
  return 0;
// Get the data from the file.
while ((num_bytes = ReadLine (filehandle, linebuf, MAX_STRING_LEN-1)) >= 0){
  if (num_bytes > 0){
   // Do something with the bytes you read from the file...
 // Check if an error occurred while reading from the file.
 if (num_bytes == -1 && (error = GetFmtIOError ()) > 0){
  MessagePopup ("Error while reading from file", GetFmtIOErrorString (error));
  return 0;
Message Edited by Wim S on 10-10-2006 03:22 PM
(3,772 Views)
Thanks.
wolf4124
(3,766 Views)
