LabWindows/CVI
Read text line and save values into array
maybe it sounds so stupid, but i have frustrated for hours with this task.
i have a text file, which containts data which following format:
Reg1_name   08DE   23234
Reg2_name   09DE   13827
Reg3_name   0ADE   19283
i want to read the line and save the values at the end of each line into an array.
My code:
char reg_name_tmp;
unsigned int reg_add_hex_tmp;
unsigned int reg_val_tmp;
char reg_name[19];
unsigned int reg_add_hex[19];
unsigned int reg_val[19];
file_handle = fopen (file_path, "r");
while(fgets(file_line,200,file_handle)!=NULL)
                    Scan(file_line,"%s    %x   %d",&reg_name_tmp ,&reg_add_hex_tmp,&reg_val);
                    reg_val_int[counter++] = reg_val_int_tmp;
There was always error.
Can somebody help me ?
(4,710 Views)
What error?
(4,707 Views)
i got : NON FATAL RUN TIME ERROR: Attempt to write beyond end of string.
(4,704 Views)
If you have an error message, you can try to get some explanation in the help, see http://zone.ni.com/reference/en-XX/help/370051V-01/cvi/libref/cviruntime_errors_and_warnings/ It will tell you that your output array is smaller than the given format specifiers and input parameters require;
In the given code there is only one place with a format specifier, and only one instance of a string: You have
char reg_name_tmp;
but this is a single character while you probably want to read the string 'Reg1_name'... Try to use reg_name instead...
(If you report an error in the future is it even better to specify the line where the error occurs, it may not always be obvious Smiley Wink)
(4,699 Views)
hi, thank for ur replies.
i have found a work around by using "strtok"
Here is the code, in case somebody interests
               char * token;
                while(fgets(file_line,100,file_handle)!=NULL)
                    unsigned int intern_cnt = 0;
                    token = strtok(file_line,"\t");
                    while(token != NULL)
                        token = strtok(NULL,"\t");
                        intern_cnt++;
                        if(intern_cnt == 2)
                            reg_val_int[counter++] = atoi(token);
(4,698 Views)
...or more simple:
counter = 0;
while (fgets (file_line, 200, file_handle) != NULL)
      Scan (file_line, "%s[xt32]%x[x]%d", reg_name, &reg_add_hex_tmp, &reg_val[counter++]);
(4,694 Views)
