LabWindows/CVI
Reading RS232 Output
Hello !!
I am try to program Digital Protactor PRO 3600 (In short Inclinometer) via Rs-232 Protocol. I had configured Port first , then switching OFF hansshaking  , then  fluhes input and ouput register. After all these steps i made RTS line low and then High  ( Digital protactor responds to PC when RTS is high only) . i am using Function COMRD but i am un able to read the output, every i get  "Zero value ". How i can use COMRD to read the output... i had also tried inp function in loop but not working as well....
Saqib Athar
(5,040 Views)
Hi Saqib51,
Please reference this function help explaining the ComRd() function. http://zone.ni.com/reference/en-XX/help/370051V-01/cvi/libref/cvicomrd/
Does the function return a timeout value? How many bytes are you specifying on each read?
Kevin S
(4,992 Views)
