LabWindows/CVI
Real time plot
I want to plot time (x-Axis) vs some sensors collected data (y-Axis) in real time mode. I tried to use strip chart to do the work, but I need to have a fixed frequency to do that and I don't have.
I only want to see in the graphs the last 5 minutes of plotted data. Do you know any object or technique to do it? If a 3rd part graphical library do this, it is also a possibility.
Thank you in advance.
(4,322 Views)
This seems very related to this thread, and I suggest you to refer to Luis answer for your needs.
I suggest you to keep all related questions in the same thread so that it will be easier for you and for us to discuss them aiming at the exact problems. Smiley Happy
(4,300 Views)
Try this real-time plotter for scientific simulations. It is called LiveGraph (http://www.live-graph.org). In my case it helped, although I am not sure of your case.
(4,254 Views)
Just visit
http://www.oscilloscope-lib.com
Cheers!
(4,122 Views)
