LabWindows/CVI
Reference clock synchronization multi chassis
When using reference clock synchronization with PXIe_100 with SMA 10 Mz clock input , if the input is turned off aquisition stops and task done call back is recieved.But i wish the aquisition to continue with internal clock .How to achieve this ..
(1,589 Views)
Why would the input 10MHz stop?
I guess it would take some time for the PXI Chassis to switch from external 10MHz to the internal 10MHz clock.
Santhosh
Soliton Technologies
(1,582 Views)
Yes.Ideally it will not.But if it fails ,i need the aquisition to continue with minimum disturbance.The present issue is the acquisition stops ,which is not desirable for my application.
(1,574 Views)
