LabWindows/CVI
Refresh the user interface
My program runs ~4 minutes. It works fine, but when i select any other thing on the desktop, my programm does not update the screen.
I use  ProcessDrawEvents but the effect is still the same. When my program stops I can see all messages. What can i do ?
(4,373 Views)
Hi Albert,
Do you have any tight loops running in your code? If so, try throwing in a ProcessSystemEvents call there as this should free up your UI to accept messages.  I am suprised ProcessDrawEvents didn't work. Where did you actual put the call to ProcessDrawEvents? Is your program spawning off new threads and creating panels in those threads? The reason I ask that is because if you call ProcessDrawEvents in a multithreaded program, only the panels created in the current thread are guaranteed to be updated fully.
Maybe a little more description on what you program is doing would help out
Best Regards,
Jonathan N.
(4,362 Views)
