LabWindows/CVI
Relative Paths
JB,
Since you're planning on sort of automating the editing of the project file, you might want to look at this example:
C:\Documents and Settings\All Users\Documents\National Instruments\CVI85\samples\dotnet\FileSystemWatcher
You can probably use some of that
Message 11 of 18
(2,540 Views)
JB,
You can probably use some of that code
Message 12 of 18
(2,540 Views)
JB,
You can probably use some of that code o
Message 13 of 18
(2,540 Views)
JB,
You can probably use some of that code to
Message 14 of 18
(2,540 Views)
JB,
You can probably use some of that code to monitor
Message 15 of 18
(2,540 Views)
JB,
You can probably use some of that code to monitor when
Message 16 of 18
(2,540 Views)
(Sheesh... I hate it when this happens)
JB,
You can probably modify that example to monitor the file, such that when it changes, you can run your script to update the file.
About the path issue in general, you make a compelling case. For the next version of CVI, we'll definitely consider extending the relative-to-project criteria for all paths.
Luis
Message 17 of 18
(2,533 Views)
If you control all the source files in your project, then instead of using "Include Paths" in CVI, you could also try using relative paths in the include directives, like:
#include "../../foo/foo.h"
This may be more maintainable and would work in all C compilers.
Message 18 of 18
(2,500 Views)
