LabWindows/CVI
Release the pointer obtained from strtok
Having the following code:
char *Token = NULL;
Token = strtok("string","s");
How can I release the Token after I will no longer use the variable?
(3,919 Views)
what do you mean by 'release'?
If you want want to free allocated space I'm not sure it's necessary in this case.
Usually, when you allocate space to a pointer with malloc() or other functions, use free().
(3,914 Views)
Hi Danut81.
There is no storage associated with your variable Token; it is a char * which the function strtok() sets to point to the next token found in your string, so there is nothing to free.
Colin.
(3,899 Views)
Don't "free" the Token. It's (just) a pointer into the "string" you want to process by strtok(). Similar to strchr() and others.
/* Nothing past this point should fail if the code is working as intended */
(3,898 Views)
Bingo!
(3,896 Views)
Thanks for the information.
Topic closed
(3,890 Views)
