LabWindows/CVI
Remote Control of CANoe
Currently I'm trying to remote control CANoe (11.0.47 (SP1)) from CVI (2012).
I have already found the solution for starting CANoe from CVI with "LaunchExecutableEx();". This function just starts the CANoe64.exe but until now I did not find any further command or function in the CVI-help that suits my problem.
The solution I already have for interacting with CANoe is based on Visual Basic Script. (thanks to CVI community!)
I wrote a little .vbs with the function I wanted and included the "shell32.lib"-library as well as the following code:
#include "shellapi.h"
ShellExecute(NULL, NULL, "c:\\...\\com_code - Test2.vbs", NULL, NULL, 0);
It works quite well so far, but actually I'm searching for a better solution in ANSI-C, that I can directly implement in CVI.
So my question is: Is there a possibility to directly control CANoe from CVI? For example: starting or stopping the measurement?
(3,244 Views)
Could you disclose the content of your .vbs files, please?
I wonder what type of interaction you have with CANoe process, and I'm too lazy and busy to find by myself.
Carlo A.
Megaris
(3,154 Views)
Hi Carlo A.
Thanks for your reply.
I have already found a suitable solution for my problem but if you are interested in this topic as well, I can tell you the solution I found.
I am very sorry that I forgot to update my question.
Best regards
Rainer
(3,149 Views)
