LabWindows/CVI
Remote exe call
I have built an exe that reads a datalogger connected to com 2, how can I call the exe from a networked pc to execute on the remote pc that has the logger attached? If I call the exe from the networked pc it tries to read the local pc that does not have the logger attached.
(3,321 Views)
You may use one of the freeware programs available in the internet.
For example there is a freeware command-line utility called "PsExec" (from the PsTools suite), that you can download from the "www.sysinternals.com" site.
Regards
Giovanni
(3,321 Views)
