LabWindows/CVI
Repeated gated single pulse generation
I am trying to upgrade a (quite) old nidaq legacy software, and I am blocked on a generation of gated single pulse signal using a counter.
I am using a PCI 6733, and I want that after each digital trigger on PFI9, the counter 0 generates a single pulse of controlled delay and duration.
Using the provided NI examples, I succeeded with the following code to generate the pulse after the first trigger. However, the following digital signals do not trigger the pulse.
TaskHandle taskHandle
DAQmxCreateTask("",&taskHandle)
DAQmxCreateCOPulseChanTime(taskHandle,"Dev1/ctr0","",DAQmx_Val_Seconds,DAQmx_Val_Low,1.00,0.50,1.00);DAQDAQmxCfgDigEdgeStartTrig(taskHandle,"/Dev1/PFI9",DAQmx_Val_Rising);
DAQmxStartTask(taskHandle);
How could I rearm the counter, so that it generate the pulse after each trigger, and not only the first one ?
As a side question, is possible to specify which clock to use to count the delay ?
Message 1 of 1
(1,037 Views)
