LabWindows/CVI
Repeater for Netowrk Variables thru a Server
Hi  a little description of the setup, Multiple Computers are transmitting Network Variables on a LAN, all communications on LAN is working as expected. Attached to the LAN is a Server it is the only access to the LAN and the only way to view the Network Variables outside of the LAN is thru the server. Is there a simple way for the server to repeat the signals on the LAN out to another network . Besides creating a program that is simply aliasing every single signal that is on each computer.
Message 1 of 1
(1,031 Views)
