LabWindows/CVI
Retrieving from a list..
Trying to get back in LabWindows/CVI so I hope you can offer some help?
We are trying to rewrite some LabView functions, we do not have the source code.
At this point we have an ini file with a number of sections, one of which has a large number of entries, 141, at present, which we are displaying to a Text box, for the moment.
We need to do the following:
  1. To find in the displayed list a particular product, by typing if possible. At the moment it is a scroll bar and then select.
  2. On selection (double click or click and OK) of this product go off and perform some action
Thanks for the help
Simon
(3,474 Views)
Happy to hear you here again!
I would suggest to move from a textbox to a table: the table control has some built-in sorting and finding facilty that can simplify the task of finding the desired element.
To select and activate, I normally set a callback for the table into which I trap the event EVENT_LEFT_DOUBLE_CLICK and use GetTableCellFromPoint (panel, control, MakePoint (eventData2, eventData1), &cell); to retrieve the cell the user clicked on. Pay attention at the help for 'Panel coordinates' field.
(3,471 Views)
Along with GetTableCellVal (PANEL, PANEL_ProductSelectTABLE,activeCell, CelValue) I was able to get to where I wanted to be.
Simon
(3,455 Views)
Just as a side note, in the line GetTableCellVal (PANEL, PANEL_ProductSelectTABLE, activeCell, CelValue); the highlighted parameter should be the panel handle, not the resource ID assigned to the panel in the UIR editor. It may happen that the line works if those values are equal, but this is just a coincidence that cannot be guaranteed in every condition.
(3,452 Views)
