LabWindows/CVI
Return value from stored procedure in LabVIEW
I am trying to get the return value from a stored procedure using the database connectivity toolset or other options if they work.
Here is a sample of the stored procedure:
spTabtempINSERT (Test_name (char(64)), Test_measurement(Int))
On success returns an integer which is the positive, non-zero TestID.
I can get the stored procedure to work fine but can't get the return value.
Brian
(3,474 Views)
(3,461 Views)
