LabWindows/CVI
Rich Text Box - Default Font Color?
I'm trying to add a Rich Text Box (the ActiveX 6.0 SP4 version) to my project. I'm using CVI 7.1.
The problem I'm running into is changing the default font color. I can change the background. Why can't I change the foreground in the font setup screen? Trying to change the font color does nothing. What do I need to do?
(I saw the tip about changing the control from "OPERATE" to "EDIT".)
I've attached a screen shot showing what I'm trying to do.
(6,655 Views)
I don't know why you can't set the default color in the UI editor. It seems to be a problem with the control.
However, you can set it at runtime. Check out the richTextbox sample program in \samples\userint\activex to see how to set it programmatically.
Hope this helps,
- jared
(6,620 Views)
Jared,
I don't have that example. It must be a CVI 8.0 example. I only  have 7.1.
Can you post a snippit?
(6,537 Views)
After looking high and low, I finally figured it out.
The RTF control does not have a ForeColor property like it has a BackColor property.
Instead, it has a SelColor property.
When used without a selection, SelColor changes the color going forward.
(6,530 Views)
Here is the rich text sample program. It was introduced in 8.1.
(6,503 Views)
