LabWindows/CVI
RichText box tab control
is there any way we can enable the tab control in the active x richtext box?
Normally, when we press tab, it rotates among the controls on the user interface. Given in the help file, user has to press CTRL+Tab to see a tab space in the richtext box. but i also have an easytab instrument in my interface, so pressing CTRL+Tab actually toggles between the panels on the easytab.
It is also stated in the help file that there is a property called tab stop to allow user to press tab like a normal word processor. I can't seem to find this property in LabWindows though. Is it available in LabWindows??
Regards
AL
(3,882 Views)
Hi AL,
You could filter out the CTRL-TABs by using an EVENT_KEYPRESS panel callback:
if ((GetKeyPressEventModifiers (eventData2)>> 16==VAL_MENUKEY_MODIFIER>> 16) && (GetKeyPressEventVirtualKey (eventData2)==VAL_TAB_VKEY))
SetKeyPressEventKey (eventData2, VAL_TAB_VKEY, 0, VAL_MENUKEY_MODIFIER << 16, 0, 0);
See attached .c source.
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(3,878 Views)
Hi SandmanUK,
your code was not able to work on my program.
I think the problem lies in the easy-tab instrument which seems to absorb this event.
1 way that i know of is to use the below statement:
RichTextLib_IRichTextSetSelText (TextHandle, NULL, "\t");
But i would like to do away with this because when i lock the textbox, it still accepts and display tabs which is what i don't want.
Any other solutions??
Regards
AL
(3,860 Views)
Hi
anybody uses richtext or easytab intruments knows a way out of this?
Regards
AL
(3,825 Views)
