LabWindows/CVI
Ring control's problem (CVI6.0)
I am using CVI6.0 on windows XP. Strange thing that the arrow on the drop down ring control is disappearing.
I see other users having similar problems. Here is a ref. to an old msg.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000BF2E0000&UCATEGORY_0=_318_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTION_0=Ring+control%27s+problem+%28CVI6.0%29&USEARCHCONTEXT_QUESTION_S=0
Any solutions. It is weird. I removed the control, added a new control. It had arrow. Moment, I ran my program, the arrow disappeared. Now arrow is gone, even when I open my UIR file in the editor.
(3,681 Views)
The only solution we found was the one I added at the end of the previous discussion you referred to.
Martin
Martin
Certified CVI Developer
(3,681 Views)
Try downloading the CVI 7.0 evaluation version to see if the same problem exist there. I believe this problem has been fixed in 7.0
Bilal Durrani
NI
Bilal Durrani
NI
(3,681 Views)
You may also want to generate the ring control programatically, this should eliminate the shinking arrow problem. Basically something like this:
PANEL_RING = NewCtrl (hPanel, CTRL_RECESSED_MENU_RING, "", 72, 87);
SetCtrlAttribute (hPanel, PANEL_RING, ATTR_CONSTANT_NAME, "RING");
SetCtrlAttribute (hPanel, PANEL_RING, ATTR_SHORTCUT_KEY, 0);
SetCtrlAttribute (hPanel, PANEL_RING, ATTR_DATA_TYPE, VAL_INTEGER);
InsertListItem (hPanel, PANEL_RING, 0, "one", 1);
InsertListItem (hPanel, PANEL_RING, 1, "two", 2);
InsertListItem (hPanel, PANEL_RING, 2, "three", 3);
InsertListItem (hPanel, PANEL_RING, 3, "four", 4);
This way the arrow should be there everytime you run your app. This is fixed in CVI 7.0, so as
Bilal says give the eval version a try.
Juan Carlos
N.I.
(3,681 Views)
I don't see the problem in CVI7.0. But I have to use CVI6.0 for this
project.
Thanks anyway.
> href="http://sine.ni.com/apps/we/nioc.vp?pc=res&cid=11104〈=US&p_0=eval">version
> been fixed in 7.0
> Bilal Durrani
> NI
(3,681 Views)
