LabWindows/CVI
Ring controls Text boxes Anyone?
I have a ring control that when selected and run generates text into the text box, but when i select a new option in ring control the text box doesn't clear itself automatically. The text box clears after I hit the run button .
Here is what it uses to clear when i select a new selection in ring control and hit run button
ResetTextBox (PnHdl [ CONNECT ], CONNECT_TEXT, "\0");
Can I make this text box clear itself of the contents when I make a new selection from the ring control instead do I have to wait till the run button is hit.
Thanks a bunch in advance.
(3,383 Views)
The ring control will receive an EVENT_VAL_CHANGED event followed by a EVENT_COMMIT event whenever a user changes its value. Simply install a callback function for the ring and on one of these events, clear the text box.
Hope this helps.
Alex
(3,377 Views)
Thanks man, worked just fine. I guess I didn't know where to reset the box.
(3,373 Views)
