LabWindows/CVI
Rings in Tables
CVI 2019, Win10.
Why does ATTR_CTRL_INDEX not work with Ring controls in Tables?  They appear to be rings.  They work mostly the same as panel ring controls.  But the only way to set or get a Table ring index is to set or read the character string value ( SetTableCellAttribute  and GetTableCellAttribute ).  In order to get a numeric index, one has to compare text strings.
This is absurdly complicated.
(2,868 Views)
Accepted by topic author hendra@ngms
The following seems to work for me...
int row=eventData1, col=eventData2;
char tableCellVal[80];
int index;
GetTableCellVal(panel,control,MakePoint(col,row),tableCellVal);
GetTableCellRingIndexFromValue(panel, control,0,MakePoint(col,row),&index,tableCellVal);
SetTableCellValFromIndex(panel,control,MakePoint(col,row),index);
(2,815 Views)
Thank you! I searched around and did not find this group of functions. Works perfectly.
(2,803 Views)
