LabWindows/CVI
Rohde & Schwarz ZVB20 save in S2P format
I try to save R&S ZVB 20 result into s2p format with the command
MMEM:STOR:TRAC 'name of the trace', 'C:\Rohde&Schwarz\Nwa\Traces\test.s2p'
It does not work and shows error "-257, "File name error; MMEM:STOR:TRACE 'MeasTrace','C:Rohde&SchwarzNwaTracesTest.s2p"'
Any suggestion?
(3,390 Views)
This might just be a typo in your post, but the filenames you show are not actually the same. The error message shows:
    "C:Rohde&SchwarzNwaTracesTest.s2p"         // A suspicious absence of '\' characters
while your post shows a different one:
    "C:\Rohde&Schwarz\Nwa\Traces\test.s2p"
Might be an idea to double-check what file is specified in your source code (not forgetting that a C string will need to use \\ where a \ is really required) and that the corresponding directory paths actually exist.
JR
(3,372 Views)
