LabWindows/CVI
Run and compile 6.0 version project in 7.1 version
I have a project that was created in version 6.0 and i want to run and compile it in version 7.1.  It is giving me this error ( the app or DLL sbslib32.dll is not a valid windows image.  Please check this against your installation diskette.  Verify that all DLL'S used by debugee were installed in the Path.  Please help!!!!!!!!!!
(2,850 Views)
Hello Sonu,
Is your original application calling the sbslib32.dll? If so, is the same version of the dll on the current computer? When are you getting this error, when you open the project, when you compile it or when you run it?
If all else fails, I think it might be better for you to create a new project in CVI 7.1 and add in all the source files and libraries that you are using.
Hope this helps. Please feel free to reply if you have additional questions.
Jack J.
(2,829 Views)
