LabWindows/CVI
Run external .exe in Labwindows
Hey guys,
Im looking to run the HEX2BIN.exe dos application (as found here: http://www.tech-tools.com/d_hx2bin.htm) in my
Labwindows Application. Now in the command line I use the application like so (the Source .hex file and Destination .bin file):
C:\<location>\ HEX2BIN.EXE Project.hex proj.bin
 Now question is how would I implement this into my Labwindows App, I had a go at using both System() and LaunchExecutable() (as suggested http://forums.ni.com/t5/LabWindows-CVI/Function-to-launch-an-external-application-in-CVI/td-p/219340) but I receive a  NON-FATAL RUN-TIME ERROR:   "BootloaderInterface.c", line 641, col 17, thread id 0x00000B9C:   Library function error (return value == -19 [0xffffffed]).
//          Display File Browser
int CVICALLBACK BrowseFileCallback (int panel, int control, int event,void *callbackData, int eventData1, int eventData2)
	switch (event)
		case EVENT_COMMIT:
				//FileBrowser_Refresh (panelHandleFileBrowse, PANELFILE_FILEBROWSER, 0);
				//DisplayPanel (panelHandleFileBrowse);
				//system("c:\\Documents and Settings\\cepeeng\\My Documents\\CEPE_RH\\CEPE Projects\\Bootloader_PIC_Project\\HEX2BIN.EXE Project.hex proj.bin");
				LaunchExecutable("c:\\Documents and Settings\\cepeeng\\My Documents\\CEPE_RH\\CEPE Projects\\Bootloader_PIC_Project\\HEX2BIN.EXE Project.hex proj.bin");
		break;
	return 0;
(6,930 Views)
Just a suggestion - not sure if this will help:
Documents and Settings, My Documents  and CEPE Projects contain spaces.  The function may read them as the end of a segment of the command.  Move your executable to a directory that contains NO spaces (personal preference - I HATE directories with spaces in them and I ALWAYS use underscores when naming folders and files) and see if this helps.
Judy
(6,924 Views)
Thanks Judy for the response. I will give that a whirl and see what I get.
Cheers
(6,908 Views)
Have just tried that method but unfortunately no luck....any other suggestions?
(6,906 Views)
Ok so I am trying another way around this. Instead of trying to open the .exe directly I have put the following inside a .bat file and try to run that instad
C:\\Test\\HEX2BIN.EXE Project.hex proj.bin
pause
 Now this works fine when I run the .bat physically,  but as soon as I try to run it inside the Application by either sytem() or LaunchExecutable() the .bat starts up but sais "The system cannot execute the specified program".
(6,898 Views)
Accepted by topic author ApeKind
Solved: when running the .exe it needs the full location of both files (c:\...\file.hex and c:\...\file.bin), the hex2bin.exe needs to be in the root file of the application, and the file location needs to have NO spaces
(6,876 Views)
Thanks ApeKind. This helped my application.. I was looking for something similar.
(6,868 Views)
