LabWindows/CVI
Running DOS command in CVI
I am trying to open a file through CVI. I know that LaunchExecutable function can launch an excutable file. However, what I am trying to do is to open a file through my executable, which is an application. Please see the attached screen shot of the command prompt to get a better idea.
Thanks.
(3,834 Views)
What's your exact problem ?
LoadExecutable should work fine. However you might have to give the full path to your application and data. Something like
LoadExecutable("C:\path\to\broadcaster32.exe /b C:\path\to\bkgd_direct_imp_pid_186_187_que");
should work.
Note that there is also the ANSI C function system(). That function waits until the end of the started command instead of continuing the launching program.
Message Edited by markus kossmann on 08-07-2006 01:03 AM
Message Edited by markus kossmann on 08-07-2006 01:07 AM
(3,817 Views)
Thank you Markus. This solved my problem .. I was initially trying: LaunchExecutable ("c:\\path\\broadcaster32.exe /b bkgd_direct_imd_pid_186_187.que")... But trying the way you suggested wroked for me.
(3,788 Views)
For future reference, if you use OpenDocumentInDefaultViewer() in CVI you do not need to know the path or even the name of the application to open a file for the user.
http://forums.ni.com/ni/board/message?board.id=180&message.id=18104&requireLogin=False
(3,750 Views)
