LabWindows/CVI
Running Matlab from LabWindows CVI using current versions
I want to run MATLAB 2019a (and its various functions) from LabWindows CVI (2017). I was trying to use the built in project on the CVI samples folder to interface but get an error message when the 'LAUNCH MATLAB' button is pressed (below is a screenshot). I browsed the forum and all the relevant posts are from about a decade ago. Can anyone kindly tell me that if it is possible to interface with MATLAB from CVI using the current versions of both the softwares?
(3,226 Views)
That FP may be compatible only with a much older version of Matlab.
Did you try re-creating the Matlab activeX instrument for the version you have?
S. Eren BALCI
IMESTEK
(3,134 Views)
