LabWindows/CVI
Running NI CVI81 rs232 samples
I am trying to understand how RS232 commands are sent out the serial port.  I have a loopback cable going to COM2 of my pc and using hyperterminal to check the commands going out COM1.  When I run LabWindows/CVI RS232 serial sample, and step through the code, the hyperterminal receives the command after I have step past several lines of code form where I expect to see the command???  I
(3,021 Views)
Duplicate post
Jonathan N.
(3,003 Views)
