LabWindows/CVI
Running a CVI application on www
Hello
How can I make a CVI (2009) application run on the Internet ?
Regards Per
Message 1 of 8
(4,748 Views)
Do you have the internet toolkit?
Message 2 of 8
(4,698 Views)
Yes I do.
Message 3 of 8
(4,690 Views)
A web server is included in the Enterprise Connectivity Toolkit. By setting up and connecting to the web server, you will be able to monitor and control the operation of your front panel through a web browser. The INET_RegisterPanelAutoUpdate function is used to export a LabWindows/CVI user interface panel onto the Web. Once a client requests the image of the panel, the server periodically sends an updated image of the panel.
Message 4 of 8
(4,687 Views)
I can't find an "Enterprise Connectivity Toolkit" for LabWindows/CVI.
From the NI Web site the available CVI toolkits are:
  • Database Connectivity (SQL) Toolkit
  • Advanced Signal Processing Toolkit
  • PID Control Toolkit
  • Execution Profiler Toolkit
So I can't find where the INET_xxx functions are.
Could someone help me?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 5 of 8
(4,311 Views)
Hi.
Unfortunately, The Enterprise Toolkit has been EOL'ed, and is no longer sold. The functionality for creating web servers is not included in CVI as the lower level function calls necessary to do so exists within the Win32 API. If you wants to make a web server in CVI, you will need to use the Win32 interface in order to do so and youl have to write the lower-level code yourself.  Microsoft's resources should have information and documentation on all of the function calls.
Tom
Application Engineer
Message 6 of 8
(4,250 Views)
Could you explain which are these lower level functions?
Could you give me a link to these resources?
I haven't been able to find this kind of functions...
Vix
Using LV from 7
Message 7 of 8
(4,243 Views)
Hi.
Unfortunately I am not familiar with this functions either.
I think this page might contains some help on the topic.
http://msdn.microsoft.com/en-us/library/ms692635%28v=vs.85%29.aspx
Message 8 of 8
(4,236 Views)
