LabWindows/CVI
Running batch files and redirecting output to a file in LabwindowsCVI
I am trying to run a batch file which gives output to command prompt. I want to capture that data to a file.
I am using LaunchExectableEx(d:\\myfile.bat >d:\\trial.txt,"",handle).This command creates a file, but there is no data in the file.
Can anyone help me in this regard?
(5,916 Views)
Hello ax,
I wasn't able to reproduce the problem you are seeing.  I created a quick batch file:
@echo off
echo Hello World
pause
and ran the following command:
LaunchExecutable ("c:\\helloworld.bat > c:\\helloworld.txt");
and the output file was correctly written and saved.
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(5,885 Views)
Just a guess. The > operator only redirects output written to standard output; not standard error. If the batch file calls things which write to standard error, that output would not be captured in the file.
Try:  LaunchExectableEx("d:\\myfile.bat 2>&1 > d:\\trial.txt","",handle);
This will redirect both standard out and error to the file.
Hope this helps,
-alex
(5,880 Views)
