LabWindows/CVI
Running in Compiler Define Switch?
Difficult to know how to ask this question?  Is there a #define that lets me know if I am running in CVI or as an executable.  Would be nice for debuggging, as I can put in test code that would not execute when I create the executable for distribution.
Just wondering..
Thanks, David
(4,704 Views)
Hello Microanalytics,
If I understand well, you're asking if there's a define that allows you to separate code run in the Debug configuration from the one run in the Release configuration. If that is so, I think this resource might be of help.
= Nelu F. || National Instruments.
(4,700 Views)
You can use BeingDebuggedByCVI () instruction too.
(4,696 Views)
