LabWindows/CVI
SQL Error
Hello:
What's the meaning of SQL Error Code -2147467259?
My situation is Microsoft dBase Driver(*.dbf) with CVI and Windows 2000.
I've got ditribution Problem.
My Program running well on My PC.
But Distribution to other PC, I got that error code.
Please help me.
(4,430 Views)
Hello 43Chlee.
If you need distrution a your Cvi apllication with CVI and Cvi sql toolkit , in the PC destination you Should install Cvi Sql toolkit .This is hard work , but there is another solution ; Only you must copy a some file in the aplication Directory of the destination PC , is you use a MDB( Access) Database , you must copy this files( They are in the your computer 😞
cviauto.dll
cvidb32.dll
IVCD.LIC
ivlib.dll
ivsql08.dll
ivutl08.dll
Best Regards
Tximis
(4,428 Views)
Where are these files?  I am noticing that I don't have the last couple of those files on my development machine.  Should these have installed with the sql toolkit or cvi?  I am using lab windows\cvi 7.0
(4,293 Views)
cvidb32.dll and cviauto.dll are dlls that ship with the sql 2.0 toolkit. The other files used to be provided with older versions of the CVI sql toolkit. These are versions prior to 2.0 and you do not need them with the newer versions of the toolkit. The readme for the toolkit lists the files installed by the toolkit. You can find the readme in the toolkit installation folder.
Message Edited by bilalD on 02-08-2006 09:00 AM
Bilal Durrani
NI
(4,284 Views)
Thanks!
(4,277 Views)
