LabWindows/CVI
SQL Toolkit 2.0 under windows 2000
Using the commaned DBImmediate SQL(...)
from the SQL toolkit 2.0 with Labwindows/cvi 5.0 (&6.0)
under windows 2000 I get the following error message
Automation Error
automation error code-2147352537 0x800200003
member not found
Any Idea ?
Thank you in advance
Andreas langer ( Original message sender )
Brosh Betzalel ( sorry that i didnt answared your question )
I also tried to run the sample projects in the SQL toolkit sample directory and most of them retured the
same problem
Will the "enterprise connectivity toolset" solve this problem ?
(3,293 Views)
You are using new ADO components in Windows 2000, you need an update to 2.0.6 of the SQL toolkit to work under Windows 2000. Contact our support engineers to get an update through http://www.ni.com/ask.
Best Regards,
Chris Matthews
(3,293 Views)
