LabWindows/CVI
SQL Toolkit DBCreateParamChar problem with Interbase
Hye.
I have problems with using of CVI SQL TOOLKIT DBCreateParamChar() statment.
I create a stored procedure "My_Proc_Stoc" on my database wich have a char(5) input parameter.
I use the DBCreateParamChar() to set the input parameter but I have some problems.
This is a example of my source code :
int rescode;
char par[6];
   hstmt = BDPreparedSQL(handle, "My_Proc_Stoc);
   rescode = DBCreateParamChar(hstmt,"",DB_PARAM_INPUT,par,"");
   rescode = DBExecutePreparedSQL(hdbc);
I the "par" variable is not set the statment works, but its not what i want to do.
When I set the "Par variable like this the statment works :
par[1]='1';
par[2]='2';
par[3]='3';
par[4]='4';
par[5]='5';
When I set the "Par variable like this the statment doesn't work :
par[0]='1';     // Problems when trying to set the first element of the char table
par[1]='2';
par[2]='3';
par[3]='4';
par[4]='5';
par[5]='6';
Do you know what is the problem in the second example ?
have you examples of use ?
PS : I have used stored procedures whith other input types (int, short, .. ) and it works well. The problem was on tying to set an input Char parameter.
Thanks.
Message Edité par lio33 le 10-26-2005 05:52 AM
(3,563 Views)
Problem of use of char[].
Must use the strcpy fonction before use the DBCreateParamChar() Statment
strcpy(par,"text to pass in stored procedure parameter");
resCode=DbCreateParamChar( hstmt, "", DB_PARAM_INPUT, par, sizeof(par));
(3,552 Views)
While your second post shows what is probably the best solution, I suspect the issue with the setup in the first post is that the string is not null terminated.
par[0]='1';
par[1]='2';
par[2]='3';
par[3]='4';
par[4]='5';
par[5]=0;
would create a terminated string.
(3,545 Views)
