LabWindows/CVI
SQL Toolkit and stored procedures
Hi
I am having trouble to get the return values from a stored procedure (MS SQL Server 7.0) in CVI 6.0. My toolkit version is 2.04. I only get value 0 back. I read through the pdf manual a couple of times, but still does not understand where the problem can be. I has also tried DBRefreshParams() and DbSetParamChar(), but then I got an error when I try DBExecutePreparedSQL().
I have attached my stored procedure (procedure.txt) and my C function to call this procedure (function.c).
Please, if you know anything about the toolkit and using stored procedures let me know. I am grateful for any suggestions.
Regards
Peder Olav
(4,999 Views)
Peder,
I looked at the code, but was unable to run it because of the values from the .uir are used in the code, and that was not attached. I looked at the stored procedure, and everything in the text file looks alright. When you say ou get a 0 back, do you mean from the DBExecutePreparedSQL(handleProcedure)?
I understand why you would then make a call to DBRefreshParams() or the like, but what error message do you then get back from DBExecutePreparedSQL? Some ODBC servers do not support DBRefreshParams
Daniel McChane
Application Engineer
(4,998 Views)
Hi Daniel
In my database I have, e.g. XNumber = xxx, ProductName = sa22, and ProductId = 862.
When I say I get 0 back, I mean when I watch retParam or outParam. I used the code below.
Status = DBGetParamInt (handleProcedure, 1, &retParam);
Status = DBGetParamInt (handleProcedure, 4, &outParam);
I thought that at least one of them should return 862, if I used the example values.
I do not get any error message, when I run the code I have in the previous attached file (function.c).
I get an error when I replace DBCreateParamInt() with DBRefreshParams() and execute DBExecutePreparedSQL(). Does not MS ODBC server supports DBRefreshParams() ?
I attached the error message.
So my problem is when I want to get the ProductId back. I am not able to
use DBRefresParams() and when I try DBCreateParamInt() and DBGetParamInt() I get no error message, but the value is 0 even if it is another value in the database.
Please can you help me with this.
We have used the database and the stored procedures together with Borland Builder C++ and then we get the right values back.
Peder Olav
(4,998 Views)
I am having the exact same problem! I'm using Microsoft SQL Server. I'm also getting 0 as a return value no matter what the real value is.
(4,979 Views)
Hello Scott,
Could you post you code, so I can take a look at it.
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(4,963 Views)
