LabWindows/CVI
SQL toolkit 2.0 Tablebrowser doesn't show SQL fileds
hallo all,
We moved an application from a win95 machine to one running XP. I made some minor changes to the user interface and recompiled on the XP system with CVI 8.1 and the SQLtoolkit 2.0.
On the XP system the application fails with error 0x80020003.
Using the provided SQL browser on the (dbase) database leaves the SQLfields empty and running the SQL command does give the number of records but no "contents"
The same happens when using the sample databases that come with the SQL toolkit.
The flowchart sample starts  with two errors 0x80020003  then it seems to work except for the "directSQL" button wich generates the error again.
The sample tools show this behaviore on both W2000 and XP systems.
Any idea where I go wrong?
Co
(3,715 Views)
Hi Co,
I know there was a knows issue with the CVI SQL toolkit and new versions of MDAC (running on Windows 2000 / XP) this resulted in the same error code as you are seeing. did you try and upgrade the toolkit to the latest version?
Regards
Karsten
(3,634 Views)
Hallo Karsten,
The upgrade just arrived and I hope it solves my problems.
Thanks, Co
(3,618 Views)
