LabWindows/CVI
SQL toolkit Vista and windows 7 problem
Hi all.
I have a program that uses the SQL Toolkit, Its works like a dream on Windows XP.
But when i try to run the app with the same ODBC setting as xp on Windows Vista and 7 i cant connect to the database.
Does anyone know why this is happening and a solution if you have one ?
Code:
DBInit (DB_INIT_MULTITHREADED);
DatabaseHandle = DBConnect ("DSN=ITAGv11");
if (DBError ())
MessagePopup("Error","Database connection problem.");
I have attached an image of my ODBC settings.
Thanks in advance.
Help share your knowlegde
(3,827 Views)
(3,800 Views)
Adding cvidb32.dll to my distribution kit solved the problem for me. It can go either to the same folder as your executables (that's what I did), or to the windows/system32 folder. I am assuming your DSN is setup properly and testing OK? I spent some time getting my SQL Server to work as a DSN on Win-7 first.
(3,344 Views)
