LabWindows/CVI
Sanchez's answer to Keli's question
Yes, I am using Labwindows to do PID control. How can I eliminate timer or count control function inside the loop and get the whole processor speed from my computer? I also use LabView. There is an example in LabView for hardware timed control (Analog IO Control Loop(hardware timed)). Is there a similar example for LabWindows? Could you send me a simple Labwindows example that can make a loop execute at a specified time interval at a fast rate? I don't need those fancy interface, just basic codes. Thanks. Keli
(2,936 Views)
Keli
Right now we do not have an example program like the Analog IO Control Loop in CVI. To be able to have a loop execute at a specified time interval you can put a delay in the loop using the Delay function. The resolution of that function is normally 1 millisecond. You can verify the time of the loop by using the Timer function.
I hope this information is helpful.
Brian
(2,936 Views)
I had the same problem. I don't use the timers because I needed complete control the processing time. This is how I set up my code to get around using the timers. I cut pieces of my code to show you so it might not be exact but it will give you the ideal.
int main (int argc, char *argv[])
int error;
int wasOtherInstance;
// initial program load panel ect.
MainLoop();
// cleanup code close things
return 0;
void MainLoop(void)
while (ProgramRunning)
ProcessSystemEvents();
// main body of code
// this runs until the exit button is pressed
// I usaully call a function here that contains the main code
Process();
int Process(void)
int Value;
int Start;
int IgnOk
CurrentTime = clock();
CurrentTime = CurrentTime / CLOCKS_PER_SEC;
return 0;
void CVICALLBACK MenuExitCallback(int menubar, int menuItem, void *callbackData, int panel)
int Value;
switch (menuItem)
case MENU_EXIT_QUIT :
ProgramRunning =0;
(2,936 Views)
