LabWindows/CVI
Save Table and text control in a .doc file
Hi all
I m copying textbox and a table to temporary panel and save it as bitmap.but i want to make doc file in which these two controls(Text Box and Table) to be saved.also i want a file in which only these two controls saves as it is seen in the original forms.
thanks to all
(3,253 Views)
Hello Electronics,
I would suggest taking a look at the Word Report shipping example (\samples\activex\word\wordrpt.prj). In particular, if you look at the InsertGraph callback, the code saves a graph control as an image and then inserts this image into a word document, which seems to be what you want.
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(3,240 Views)
I second Wendy's suggestion to look at wordreport.fp. Also, if you don't want the table in image form but you want it converted to a Word table, there is a function in wordreport.fp that automatically converts a CVI table to a Word table. The function is called InsertCVITable.
Luis
NI
(3,226 Views)
