LabWindows/CVI
Saving canvas to a bitmap file
I have an image on canvas indicator and I would like
to be able to save it into a bitmap file using LabWindows/CVI 5.0.1.
Any advice?
Ori Idan
Helicon technologies LTD. National Instruments Alliance member in ISRAEL
Email: ori@helicontech.co.il
Home page: http://www.helicontech.co.il
Tel: +972-6-6262353 Fax: +972-6-6262405
Things should be made as simple as possible but not simpler
Albert Einstein
(3,339 Views)
Hello Ori,
There is an example in the National Instruments example program database
that does this. It seems that CVI 5.x does not have a function that saves a
bitmap
to a file. But this example does exactly that.
check it out at the following page:
http://digital.ni.com/explprog.nsf/2222373937d4e9a38625666a00831a24/b1384a94
02f57b13862564c80053702c?OpenDocument
If the link is broken, go to http://www.ni.com/support/ and then go to
the Example programs database. I used the following search string
"cvi and file and bitmap".
Good luck,
Azucena
"Ori Idan" wrote in message
news:390C236A.9B80365F@otidan.co.il...
> Any advice?
> Thanks,
> Ori Idan
> Albert Einstein
(3,339 Views)
