LabWindows/CVI
Scale coefficients in DAQmxReadBinaryI16
Hi, I'm currently using USB 6210. I'm using DAQmxReadBinaryI16 to read data and save it into a file. I try to retrieve the data using scaling coefficient.
The scaling coefficient were
    scaleCoef[3]=0.000;
    scaleCoef[2]=-0.000;
    scaleCoef[1]=0.000328723044231;
    scaleCoef[0]=0.180407148323421;
I have tried the scale coefficients in my other programs and it worked properly. Are scale coefficients return by DAQmxGetChanAttribute always the same if I use the same DAQmxReadBinaryI16 function?? Thanks for your helps.
Chew
(3,574 Views)
Yes, the DAQmxGetChanAttribute will return the same scaling coefficients that you have previously specified.  There are help files in the LabWindows/CVI Help titled DAQmxGetChanAttribute and List of Channel Properties, which is a list of attributes that are available for a value check.
Please note that the DAQmxReadBinaryI16 reads unscaled data, thus your scaling would have to happen after this function call.  Please use the DAQmxGetChanAttribute to get the DAQmx_AI_DevScalingCoeff inorder to determine what scale coefficients are needed to scale the unscaled data to a voltage.  What actual issue are you seeing?  Please describe the problem in further detail.
Samantha
(3,547 Views)
Thanks for your reply. I just want to comfirm the values of the coefficients when I called the function DAQmxReadBinaryI16 everytime.
My problem was I need to use the coefficients without create any task. So I have to set the coefficients value to constant values.
I would like to set the coefficients as constant values since everytime i called DAQmxReadBinaryI16 will get the same values. Thanks.
Chew
(3,535 Views)
