LabWindows/CVI
Scale contents on resize with a lot of controls
Is there any known issue with "scale contents on resize" when there are a lot of controls in the panel (for example 100 controls)?
I have an example with CVI 6.0 where after such a resize I see strange errors (invalid bitmap, out of memory, ...) in other sections of the program.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,132 Views)
Hello Vix,
I found the following articles that answer to a question similar to yours. Can you please take a look?
Resizing Problem on Lab Style String Control and Not on Classic Style String Control
http://digital.ni.com/public.nsf/allkb/D4B5E1C5D61243C986256AE100757471?OpenDocument
Resizing a LabWindows/CVI Table as the Panel Size is Changed
http://digital.ni.com/public.nsf/allkb/B971C0B550ED680A862570B8001390B3?OpenDocument
Antonios
(3,101 Views)
unfortunately this links don't help me because I use Classic Style controls and I don't use Tables.
I hope I will able to supply a little example showing the problem...
Vix
Using LV from 7
(3,085 Views)
