LabWindows/CVI
Scan a string of "34,35.34,65,0.214,1000...." to a double arary of A[0]=34,A[1]=35.34,A[2]=65,A[3]=0.214,A[4]=1000.....
    I have a string with the format of "34,35.34,65,0.214,1000....". What I try to do is to scan this string and get the result like A[0]=34,A[1]=35.34,A[2]=65,A[3]=0.214,A[4]=1000..... Here, A is a double arrary. I expect a simple way to do this, maybe I could use fmt function, but dont's know how to do it.
Thanks!
Jacky
(3,194 Views)
I suggest you look at the "Scan/ScanFile/ScanIn Examples" topic in the CVI help. The section "String with Comma-Separated ASCII Numbers to Real Array" might be appropriate.
Martin
Certified CVI Developer
(3,188 Views)
Hello Jacky,
as Martin already suggested you should use the function Scan. The Scan function is used to break a string up into one or more strings, integers, doubles, ... The Fmt fuction does exact the opposite, and is used to create a string from several strings, integers, doubles, ...
Scan and Fmt use modifiers to let the user describe details about the goal and/or target arguments. The modifier you should use is [x], which is the 'discard terminator' modifier. Since you want to break up the string into doubles, use %f as the target format specifier.
I do not know how many doubles you have in your string. Suppose there are ten, then the function looks like this: Scan (string, "%s>%10f[x]", A); Since the source is a string, you can leave out the %s argument and just write Scan (string, "%10f[x]", A); You should note that the function will also expect a comma after the 10th double. If this is not the case, you should treat the 10th double seperately and write Scan (string, "%9f[x]%f", A, &A[9]);
Like Martin, I suggest you take a good look at the Scanning Functions topic in CVI Help. It's not too easy I have to admit, but you really can do a lot of things with it if you understand how it works.
Success,
Wim
(3,165 Views)
