LabWindows/CVI
Scan for float in string
I'm trying to read a 4 byte IEEE 754 float from a string (array of char) using the scan function. I tried all kinds of formatting versions described in the help but I can't get it work proper. I receive a the string from a COM port. It looks like this in Hex (the float value is in [] brackets):
FF FF FF FF 86 1A 1E 6C 82 22 01 07 00 00 11 [C0 52 8F 9F] DB FF ...
The string format is always like this. The first 15 bytes are some commands I want to skip and then I need to read bytes 16, 17, 18 and 19. The result in this case should be -3.290016.
Here is the last of my many attempts to extract the float:
char buffer[24];
float myFloatVal=0;
Scan(buffer, "%4f[i15b4]", &myFloatVal);
This example returns "0" for myFloatVal.
Any advice would be most welcome!
Message 1 of 10
(8,420 Views)
Accepted by topic author rdwitt
That Scan conversion seems a bit tricky: while it performs well with doubles I am not be able to make it work with floats too Smiley Frustrated
I can suggest you a possible workaround with sscanf:
sscanf (buffer + 15, "%c%c%c%c", (char *)&myFloatVal + 3, (char *)&myFloatVal + 2, (char *)&myFloatVal + 1, (char *)&myFloatVal);
Message 2 of 10
(8,408 Views)
Roberto's solution is goog and probably more simple than bit considerations, as explained here :
http://en.wikipedia.org/wiki/Single-precision_floating-point_format
I know that it's not LV forum but the following LV implementation could be done with CVI as well...Anyway, Roberto's workaround is smarter ! ^^
Message 3 of 10
(8,400 Views)
Hi Roberto,
thank you for your reply.
I found a workaround myself but yours is much more elegant!
I masked each byte of the buffer with a unsigned short int. Then rotated each byte to the corresponding position of a float. Transferred everything to a 4 byte int with a or mask and finally cast this int to a float. As I said: It's a bit plump, but if your interested have a look:
char buffer[24]={0};
float myFloatVal;
unsigned short int a,b,c,d,erg;
a = 0x000000FF;
a = a & buffer[15];
a = a << 24;
b = 0x000000FF;
b = b & buffer[16];
b = b << 16;
c = 0x000000FF;
c = c & buffer[17];
c = c << 8;
d = 0x000000FF;
d = d & buffer[18];
erg = 0x00000000;
erg = erg | a;
erg = erg | b;
erg = erg | c;
erg = erg | d;
myFloatVal=*((float*)&erg);
Thank you for your help!
Message 4 of 10
(8,398 Views)
Hi rdwitt,
I assume that there may be problems in using shorts in your implementation: what happens when you shift a value 16 or 24 bits to the left. i.e. out of short boundaries? And on the final line?
In effect your code returns a "Dereference of a 4 byte object where only 2 bytes exist" on my machine on the cast the ends the process.
Defining all of them as int, nevertheless, gives correct results.
Message 5 of 10
(8,391 Views)
You are right,
I made a mistake while writing the code to the post. You see I'm using a computer which is not connected to the www due to some security guidelines. So it was fastest to copy the code manually..
Originally I used unsigned ints.
Thanks again
Message 6 of 10
(8,375 Views)
@Julien_2831
In the sake for simplicity, you could use this method: Smiley Wink
I agree that this is not the correct forum, I simply wanted to place a little comment on your solution.
Message 7 of 10
(8,365 Views)
You're perfectly right ! Smiley Very Happy
Obvious now, but I had not even thought about it before ! Thank's.
For CVI :
unsigned int U32_Value = 0xC0528F9F;
float Scal_Value = 0;
Scal_Value = * (float *) &U32_Value;
Anyway, since the need was to cast 4 char into 1 float, the solution you provided previously is definitely the best.
Message 8 of 10
(8,357 Views)
Another option would be memcpy:
char buffer[24];
float myFloatVal=0;
memcpy(&myFloatVal,&buffer[15],4);
Message 9 of 10
(8,328 Views)
Ah oui ! Very good !
Message 10 of 10
(8,299 Views)
