LabWindows/CVI
Scan question
I came across the following Scan expression in an instrument driver. Can anybody explains its details?
if ((Scan(rdBuffer, "%s > %s[xt44]$s[t77]", ChanA, ChanB)) !=2) return Error;
Rafi
(3,082 Views)
This statement scans a string dividing into 2 substrings, the first one from the beginning up to the first comma [,] found, the second one from that point up to the first "M" found.
In my opinion the $ sign is incorrect and should be a %.
The Scan instruction is quite complex to understand: the best is that you look into the on-line help >> Library Reference >> Formatting and I/O library where Scan function is described in full detail.
(3,078 Views)
