LabWindows/CVI
ScreenSaver running notification?
Hi happy CVI'ers,
I was wondering if there's any way to be notificied or to check if a
screensaver is currently active (ie running).
I didn't find any way in CVI, maybe with the SDK but I didn't find
anything in the help either.
Thanks for any trick I can use,
--Fred
(3,366 Views)
Hello
Check out the SystemParametersInfo function, that should help you out with the SPI_GETSCREENSAVERRUNNING parameter, but you might want to read thru the function documentation first
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,366 Views)
I've just take a look to the SDK help: seems to be what I need.
Thanks!
bilalD a écrit :
> Hello
> Hope this helps
> Bilal Durrani
(3,366 Views)
