LabWindows/CVI
Scrolling through a list box, I would like larger arrows
The application is a touch screen and the operators fingers are too large for the size of the scroll bar, can I make the arrow larger or link a larger button to do the same function
(2,908 Views)
Hello
You cannot change the size of the buttons for the list box, what you would need is to use a command button that would alter the attributes for the list box everytime the user clicks on it. Use the SetCtrlAttribute with ATTR_FIRST_VISIBLE_LINE option set, that will allow you to move the list up or down programmatically.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(2,908 Views)
