LabWindows/CVI
Select box in a Toolbar
Hi!
Is it possible to add a sleect box in a toolbar? How can I do it?
Thank you in advance
Gustavo
Message Edited by Oliveira on 10-05-2007 02:16 PM
(3,446 Views)
Good morning Gustavo.
If i understood it well, you want to change the menu (File, edit, ..) to others customized by user.
The are functions that you could use to manipulate the vi menu as you can at Programming >> Dialog & User Interface >> Menu Functions on Functions Pallete.
I build a code that allow you to do it.
Let me know if i´m right about you problem.
Filipe NI Brazil
(3,400 Views)
(3,399 Views)
Sorry again... After i sent this message, i see that its not LabVIEW!!!
(3,397 Views)
