LabWindows/CVI
Select location of cvi runtime
Hi all!
I'm pretty sure that on former versions of cvi there was the possibility to choose if the runtime and other depending dll's are installed in the application directory or in the system directory.
Where is this option gone in cvi 2013?
Thomas
(4,061 Views)
When you install multiple versions of LabWindows/CVI, only one Run Time Engine (RTE) is used. The RTE is backwards compatible.
Are you looking for this option when you are using CVI development environment or for building applications?
Evan See
(4,046 Views)
sorry, my question wasn't clear. I mean the location of the RTE and DLL's when building applications. There was an option that the distribution kit installs the RTE and DLL's inside the application folder, instead in the windows system folder.
Thomas
(4,040 Views)
I checked through the changes from 2012 to 2013 and found that that option in the dialog has been deprecated. Some additional information is available in the LabWindows™/CVI™ 2013 Behavior Changes (3rd bullet).
Evan See
(4,034 Views)
