LabWindows/CVI
Selecting a Word Table
i'm using LabWindows 7.0.
I've a Word Document that's a template of a Test Data Report. In this template i've a header text and a preformatted table with a predefined number of rows.
So, to fill the Header i've used the WordReport.fp to select the bookmarks and write the text.
For the table i've the following question: in the WordReport there's the WordRpt_SelectTable () function that needs the table handle.
My problem is that i don't know the table_handle because the application don't create a new table, so i need to get the table handle directly inside the document:
Maybe i must open the document using directly the WordActiveX instead of using the WordReport wrapper library?
If yes, once open the document how is possible to get a specified item table?
Someone can help me with some examples both for WordReport and/or ActiveX?
Thanks to everyone...
Best Regards.
Maurizio
(3,780 Views)
Nobody has some suggestion??
Smiley Sad
Thanks....
(3,763 Views)
Perhaps it will help solve a problem.
CAObjHandle   tablesHandleL;
CAObjHandle   tablesHandle;
int  i;
//====== Get handle of the tables list of the Word Document =======
Word_GetProperty (docHandle, NULL, Word_DocumentTables,CAVT_OBJHANDLE, &tablesHandleL);
//====== Get current (from index i) table handle ==================
Word_TablesItem (tablesHandleL, NULL,  i, &tableHandle);
Janusz
(3,733 Views)
