LabWindows/CVI
Send email with file attachment in CVI
I would like to send automatically an email to an user, where the results of a test are attached as file. I used LabWindows CVI 5.0.1 and ActiveX will not work. I have tested to send the email by SMTP (SendMail), but it was only possible to send text in the message body. I didn't realised to attach the file. Also I have tried to use the "cmd /c start mailto:xxx@xxx.com?subject=text" command, but I didn't find a solution. May someone help me to find a solution to send an email with file attachment.
(4,275 Views)
Good Morning .
The best option to send a mail is use the "CVI intenet toolkit".
There is in this toolkit an fp instrument to send a mail.
With this instrument is very easy send a mail with a flie.
This function send a mail
#define YOUR_SMTP_ SERVER "mailhost.terra.es"
#define TO_MAIL "f.bermejo.garapen@adegi.es"
#define FROM_MAIL "fb.Automation@terra.es"
#define SUBJECT "Es una prueba"
#define MESSAGE_TEXT "Es un mensaje de aviso de ciorrreo........."
int EnviarMensaje(void)
int error;
error = INET_SendMail(YOUR_SMTP_
SERVER,FROM_MAIL,TO_MAIL,SUBJECT,MESSAGE_TEXT,"c:\Analisis.doc");
if (error<0)
MessagePopup("AVISO","Error primero");
return 0;
return 1;
Best Regards,
Tximiskurdi
(4,274 Views)
Thank you for the answer and it will be sure an easy solution, but the email feature will be only a nice to have function in my program and it will be not possible to spend money on this. Are there any possibilities without updates or toolkits?
(4,274 Views)
> attachment.
If you have LabVIEW you could see how the OGIC library does it:
http://openg.org/tiki/tiki-index.php?page=OpenG+Internet+Connectivity+Tools
It handles attachments using base64 (MIME) encoding and
doesn't use any
ActiveX, just pure TCP. Should be easy to convert to C.
(4,274 Views)
i have same problem with Methis Elddir...
(3,474 Views)
