LabWindows/CVI
Sending String from Android to LabWindows application.
i am working on a project in which i have to make a client in android and  server is a labwindows application. Is this possible? if yes, any help to get me started is appreciated.
Thanks.
(4,781 Views)
Hey Abdul90,
What type of data are you planning on sending from the Android device your CVI Application? What kind of connection are you looking to make (TCP/IP, local, etc)? Most of the these types of applicaitons do not support high throughput data and are just occational updates. There is a an App called data Dashboard that you might want to try:
https://decibel.ni.com/content/docs/DOC-19387
Best Regards,
-KP
Kurt P
Automated Test Software R&D
(4,752 Views)
Het Kurt P,
Actualy I am planning to make an intrusion detection system, (Smart phone as a sensor). Sensor data (e.g voice, motion, images) is to be sent to Desktop pc over Wifi. where Labwindows application will generate corresponding alarms and notifications.
- UDP connection.
Is this possible?
And i cannot use third party softwares. As this is my University project.
Thank you so much for your guidance.
Regards.
(4,691 Views)
Concerning UDP Support in LabWindows/CVI, see here
(4,686 Views)
